ncatona's avatar
ncatona
AC1750 Xbox Gaming Settings
Hello everyone so I got the router updated and have been using it for school the most part, zooms and mutliple mobile phones connected and etc.
Now I started to game a little but my brother will do online stuff soon, our Nat type is strict and im looking to change that. Also I dont have QOS enabled because when it was all other devices suffered for school use. My isp plan is only 20mbps down and 5mbps upload. Give me some recommendations of what to do for that nat type, I will consider using qos when schools over.
  • Never mind it seems like that has a ton of security issues. I will possibly be going more towards the port forwarding route, and if not the DMZ but not 100% sure yet. I dont plan on using QOS even though my internet speeds are 20 mbps down and 5 mbps upload. Will port forwarding basically set me up for xbox gaming properly without any issues? I dont think theres any other settings I could do on my ac1750 besides that.
    • ncatona's avatar
      ncatona
      So I will be turning on the Upnp for the router since that helps. I am connected to the 5G and that works fine since distance is close. Any other tips or recommendations for what I could change or setup?
      • ncatona's avatar
        ncatona
