Retired_Member
Mar 29, 2020AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
On all of my devices, my AC1750/6400v2 router is no longer visible and is not broadcasting 2.4/5ghz. This happened spontaneously. I have restarted my devices, the router, and the modem. Help trouble...
- Retired_MemberMar 29, 2020
That didn't work and your links weren't helpful. However, I searched these community forums and found out that pressing the Wifi On/Off button solves the problem. I hope my post is helpful to others!
antinode
Mar 29, 2020Guru
https://community.netgear.com/t5/x/x/m-p/1882907#M152535
> [...] This happened spontaneously. [...]
Everyone says that. Some even believe it. Occasionally, but seldom,
it's true.
> [...] Help troubleshooting would be appreciated.
Here's a radical concept:
- antinodeMar 29, 2020Guru
> That didn't work [...]
_What_, exactly, "didn't work"?
> [...] and your links weren't helpful. [...]
I'm impressed that you found the link which led directly to the
suggestion, 'Pay particular attention to the "WiFi On/Off button with
LED". Did you press it?' unhelpful, and then revealed "that pressing
the Wifi On/Off button solves the problem." Many people couldn't have
managed that feat.> [...] I hope my post is helpful to others!
Many things are possible.
- additudeMar 30, 2020Virtuoso
Putting the ol' O N O F F button to the O N position works everytime....
