Anonymous's avatar
Anonymous
Mar 29, 2020
AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
On all of my devices, my AC1750/6400v2 router is no longer visible and is not broadcasting 2.4/5ghz.  This happened spontaneously. I have restarted my devices, the router, and the modem. Help trouble...
  • Anonymous's avatar
    Anonymous
    Mar 29, 2020
    That didn't work and your links weren't helpful.  However, I searched these community forums and found out that pressing the Wifi On/Off button solves the problem. I hope my post is helpful to others!
