Retired_Member
Mar 29, 2020AC1750/6400v2 no longer broadcasting 2.4/5ghz and SSID not visible from devices
On all of my devices, my AC1750/6400v2 router is no longer visible and is not broadcasting 2.4/5ghz. This happened spontaneously. I have restarted my devices, the router, and the modem. Help trouble...
- Retired_MemberMar 29, 2020
That didn't work and your links weren't helpful. However, I searched these community forums and found out that pressing the Wifi On/Off button solves the problem. I hope my post is helpful to others!
antinode
Mar 31, 2020Guru
> Your suggested fix was incorrect [...]
How, exactly? What's the difference between my suggestion and your
"solution"?
> [...] I was able to find an answer on another threat within this
> forum.
Thanks for the helpful link.
> _What_, exactly, "didn't work"?
Still a mystery.
additude
Mar 31, 2020Virtuoso
antinode,
I'll give you a kudos for "Great Effort" on your part.
Thanks for being here and working as a volunteer helping all these schmucks weasel their way thru even the trivialist of "button pushing methodology" and then, not receiving even a compliment or a thanks.....
I'll say thanks to ya on their behalf....
