maniont58
Jun 11, 2020Aspirant
AC1750/r6400v2 running V1.0.4.78_10.0.55. how to disable wireless isolation
My issue is the following. My laptop is on 5GHz, my new printer only connects to 2.4GHz. Since they are on separate networks, my laptop cannot see the printer. I believe that if I disable wi...
- Jun 12, 2020
What fixed it was that I had to enable the Guest network as well
as the option: Allow guests to see each other and access my local network
maniont58
Jun 12, 2020Aspirant
