Markg2's avatar
Markg2
Tutor
Feb 05, 2016
AC1900 & USB Flash drive
I plugged in a flash drive to the router's port, setup ReadyCloud and the data I backed up from my laptop to the FD is on the Netgear server. I have a few questions:   1. The router's LED associate...
  • JamesGL's avatar
    Feb 09, 2016
    Hi Markg2,
    Here are the answers to your question:
    1.  The router's USB LED should lit up if a USB drive is connected to the router. Can you try to plug a different drive and see if it will lit up. Try checking the two USB ports.
    2. ReadyCloud is a feature for you to access the USB drive connected to the router. You can only access files saved on the drive and not the files in your network.
