BillGeddes
Oct 27, 2024Aspirant
AC1900 and CM500 speed issue
Hooked up to Comcast/Xfinity that tells me I should have up to 300Mbps, but using wireless very close to the modem & router any speed test maxes out at about 80 (using both my windows 11 laptop and g...
BillGeddes
Oct 28, 2024Aspirant
Not new service.
Don't recall ever having a speed over 100Mbps even since we were "upgraded" to 300Mbps.
No wired connection available- silly new laptop is wifi only, and of course no wire on the phone.
Phone is airplane mode with wifi on.
Use comcast, google, and ookla tests.
Understand the router is "old," but throughput shouldn't be degraded from 600 to 100Mbps, should it?
Almost seems like I'm 'throttled' at 100... 😕
michaelkenward
Oct 28, 2024Guru - Experienced User
What do you see here?
- Advanced
- LAN Port
- Show statistics
192.168.1.11/RST_statistic.htm
Just another user with time on their hands.
- BillGeddesNov 04, 2024Aspirant
Borrowed a laptop with a wired port, and same 300 limit.
Here's the interface:
(upgrading firmware today 🙂 )- FURRYe38Nov 04, 2024Guru - Experienced User
What speeds do you see with a ethernet connected PC or laptop connected directly behind the CM modem, with out the router connected?
