BillGeddes
Oct 27, 2024Aspirant
AC1900 and CM500 speed issue
Hooked up to Comcast/Xfinity that tells me I should have up to 300Mbps, but using wireless very close to the modem & router any speed test maxes out at about 80 (using both my windows 11 laptop and g...
michaelkenward
Oct 28, 2024Guru - Experienced User
What do you see here?
- Advanced
- LAN Port
- Show statistics
192.168.1.11/RST_statistic.htm
Just another user with time on their hands.
BillGeddes
Nov 04, 2024Aspirant
Borrowed a laptop with a wired port, and same 300 limit.
Here's the interface:
(upgrading firmware today 🙂 )
- FURRYe38Nov 04, 2024Guru - Experienced User
What speeds do you see with a ethernet connected PC or laptop connected directly behind the CM modem, with out the router connected?
- BillGeddesNov 04, 2024Aspirant
Looks like a gig, eh?
So what speed to you now see with a speed test app like Ooklas installable speed test app with the PC connected directly to the modem, with out the router connected?
- michaelkenwardNov 04, 2024Guru - Experienced User
LAN3 (your only wired connection?) seems to be connected at 100 Mbps.
This is usually down to the device plugged into that port. Most PCs and laptops will have 1000 Mbps LAN support. Older ones and many other devices, such as TVs and printers, are stuck on 100 Mbps, which is fast enough for most kit.
