hiennguyen
Jul 25, 2021Aspirant
AC1900 C7000 slow wifi speeds but good wired speed
We are with Comcast 800Mbps package. I did couple of tests as below 1. Wired speed at around 550Mbps 2. Wireless speed on the 5GHz band at around 250Mbps (both devices Macbook 2019 and Windows lapt...
hiennguyen
Jul 26, 2021Aspirant
Thanks michaelkenward for reply. I really appreciate that.
As you might already see my 3rd test, same router but connection via AP, the speed was more than double (around 550Mbps).
The point I were trying to make was C7000 isn't as fast as specs (Up to 1.9Gpbs† combined WiFi speed for extreme gaming and streaming), and yes my work needs connection as fast as possiple. That's why I paid comcast for 800Mbps package.
Any suggestions on how to fix wireless connection slowness is really appreciated.
michaelkenward
Jul 26, 2021Guru - Experienced User
Did you read the link I posted?
That would tell you that you need to research what they mean by "Up to 1.9Gpbs combined WiFi speed".
As the Data Sheet says:
"†Maximum wireless signal rate derived from IEEE standard 802.11 specifications. Actual data throughput and wireless coverage will vary."
"Wireless signal rate", itself a vague term, is not the same as "wifi data transfer speed".
"Network conditions and environmental factors, including volume of network traffc, interference, and building construction may lower actual data throughput and wireless coverage.
"NETGEAR makes no express or implied representations or warranties about this product's compatibility with any future standards. 802.11ac 1900 Mbps is approximately 3x faster than 802.11n 450 Mbps. Up to 1900 Mbps wireless speeds achieved when connecting to other 802.11ac 1900 Mbps devices."
You have some of those?
We still don't know of your wifi speed is too slow for things you are trying to do.
