hiennguyen
Jul 25, 2021Aspirant
AC1900 C7000 slow wifi speeds but good wired speed
We are with Comcast 800Mbps package. I did couple of tests as below 1. Wired speed at around 550Mbps 2. Wireless speed on the 5GHz band at around 250Mbps (both devices Macbook 2019 and Windows lapt...
hiennguyen
Jul 26, 2021Aspirant
michaelkenward I am trying to understand why you keep asking unrelated questions.
michaelkenward
Jul 27, 2021Guru - Experienced User
I'm trying to understand why you are worrying about your wifi speed.
As explained, several times, there is almost certainly nothing you can do about it. Nor is there anything wrong with your modem/router.
Forget about the wifi speed and worry about what the real problem is. Maybe you can fix that.
If you are just staring at a speed meter, have fun.
