Bruce0138
Nov 18, 2017Aspirant
AC1900 grayed out internet, LAn, Wan setting under advanced steup
On PC have both lan and wifi. Connected to router via wifi , wwwrouterlogin.net. Got to advanced after loging in, went to setup. Dropdown shoes Internet, WAN and LAN grayed. Can not activate them. NO...
- Nov 18, 2017It sounds like your router is in AP mode. Try doing a factory reset through the settings: ADVANCED > Administration > Backup Settings > Erase.
TheEther
Nov 18, 2017Guru
- Bruce0138Nov 18, 2017AspirantI tried a reset before but must not have pressed long enough or hard enough. Your solution solved.
Thank you!
