mikejbennett80's avatar
Jul 14, 2017
AC1900 Nighthawk- Ethernet Ports not working
Wifi works great but when I connect to desktop via Ethernet port 1-4 there is no connection. No lights on the AC1900 or at the port plug in.    Any suggestions? Already did a factory reset.    Th...
  • JamesGL's avatar
    Jul 17, 2017
    Hi mikejbennett80,
    Try to connect a different device to the router.
    Use a different ethernet cable.
