Dallasbrown
Jan 12, 2021Aspirant
Ac1900 R6900v2 Router wont connect after newest update
Wont work at all after most recent firmware update through nighthawk app
Jan 13, 2021Guru - Experienced User
Just the app doesn't work?
Or the router doesn't work for anything? wired/wireless connections etc.
Your description wasn't very specific or clear
- DallasbrownJan 13, 2021AspirantThe router wont connect to the internet or anything. Just 2 red lights. The headline of my post says "router wont connect" figured that would cover it but guess not
- plemansJan 13, 2021Guru - Experienced User
what 2 lights are red?
What firmware is on the router?
What modem/gateway is it connected to?Is it broadcasting wifi?
Are you able to access the router gui while hardwired into it?
What caused this? Did it randomly start? Did it happen after a firmware update/settings change?
What have you tried doing to resolve the issue?
Have you tried a factory reset and reinstall?
