ashukla's avatar
ashukla
AC1900 R700 admin password not recovering
Hi,   My admin password has been changed 192.168.1.1 and its not accepting my figure print or old password.  The recover questions also does not accepts the answer. is there anyway to change the a...
  • DarrenM's avatar
    Mar 06, 2020
    Yes, you can hold the reset button on the back of the router for 10 seconds but this will reset everything on the router and you will need to set it up again, The default login will be admin/password after you do this.
    DarrenM
