Cablecons's avatar
Cablecons
ac1900 r7000 power light staying amber
I tried to set my AC1900 R7000 as an extender but after making changes and saving them the router doesn't do anything.  When I power on it goes through the light sequences and then the amber light stays solid. After about a min or so it seems to try and restart and amber light stays solid again over and over. I tried TFTP upload but the amber light does not blink to click the put button.
Any help is appreciated.
Thank you
  • FURRYe38's avatar
    What does a 10 seconds reset button press and release do?
      • FURRYe38's avatar
        Have you tried the 30-30-30 reset as last resort? If this fails then router may need to be replaced.
