jhex7000
Jul 24, 2020Guide
AC1900 R7000 Router not providing upgraded speeds on 5Ghz
My ISP upgraded my internet speeds from 100Mbps to 400Mbps. I am using an Arris TM1602A modem and the ISP tech says he is seeing the increased speeds from the modem. Whenever I do a speedtest, the be...
- Aug 03, 2020
Not sure what was causing the drop in speeds to around 100M but now I am seeing consistent download speeds around 230-250Mpbs, with that number going above 300M as I move closer to the router/modem room.I decided for now not to use an extender as I had forgotten that they impact the throughput and primarily extend the 5Ghz range.
