Romvill2002
May 11, 2021Aspirant
Ac1900 r7000
Both wifi and ethernet giving off half my bandwith speed of only 50mbps. Should be 100mbps from att modem.
antinode
May 11, 2021Guru
> 50mbps. [...]
Measured how?
> [...] Should be 100mbps from att modem.
What is your "att modem"? Maker? Model number? Is it actually a
modem, or is it a modem+router?
What speed do you see if your computer/device is connected directly
to your (unspecified) "att modem"?
(Note: "m" = "milli" = 1/1000. "M" = "mega" = 1000000.)
- Romvill2002May 11, 2021AspirantAT&T modem model BGW210 with bandwidth of 1000 megabitpersec. My network is att+modrm+Nighthawk router+devices =50mbps. If i connect directly to att modem using my laptop ehtermet is 95-100mbps. Using speedtest.
- antinodeMay 11, 2021Guru
> AT&T modem model BGW210 with bandwidth of 1000 megabitpersec. [...]
Some _parts_ of it can operate at 1000Mb/s.
A BGW210[-700?] is a "gateway" (modem+router), not a simple modem.
Cascading multiple routers can cause multiple problems.Given that you already had a wireless router in the BGW210[-700?],
why did you add the R7000?If your goal was to extend the wireless-network coverage of the
BGW210[-700?], the you might want to configure the R7000 as a wireless
access point (leaving the BGW210[-700?] as your router).Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Set Up the Router as a WiFi Access Point".
If the R7000 has some especially desirable router features, then you
might want to configure the BGW210[-700?] as a modem-only ("bridge"
mode), and use the R7000 as your only router.> (Note: "m" = "milli" = 1/1000. "M" = "mega" = 1000000.)
Still true.
