Francesco178
Oct 28, 2022Follower
AC2000 (R6850) only makes access point
hello, this is the first time that I use a Netgear product and I can't figure out how to set up the Router that works only as an Access Point. thank you
Oct 28, 2022Guru - Experienced User
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
