jalambert29
Dec 29, 2021Follower
AC2000 WAC124 How do I enable smb2
I am having issues getting Map Network Drive to work on my AC2000. the map is OK, the drive is connected to the AC2000 without any issues. When I go to map the drive I get an error message b...
michaelkenward
Dec 30, 2021Guru - Experienced User
jalambert29 wrote:
When I go to map the drive I get an error message back about running smb1 and how it isn't secure. That I should be running smb2.
That's a Windows thing. Where did you see the error message?
No point in following strange advice to dive down a blackhole of a different section here.
In addition fro the, as usual, helpful advice from plemans here's another one:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
As it says here:
This reply will solve TWO Issues pertaining to Mapping a Windows Network Drive to your USB Connected Drive on your Netgear Router. This posting applies to ALL Netgear Routers utilizing Shared USB Windows/MAC File Sharing, including all current models.
