LWBar
Oct 07, 2023Follower
AC2000 won't show up to connect
The router ssid won't show up
michaelkenward
Oct 07, 2023Guru - Experienced User
Tell us more. Won't show up where?>
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
One thing to note is that AC2000 doesn't tell us much.
AC2000 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
