yorkee
Dec 01, 2020Aspirant
AC2100 ReadyShare harddrive freespace only 750GB
I plug in a WD easystore 14TB usb drive I just bought from black friday to my AC2100 router and tried to use ReadyShare. I can access the drive via a smb test on both my phone, mac and linux box, ho...
antinode
Dec 01, 2020Guru
> I plug in a WD easystore 14TB usb drive [...]
As descriptions go, an actual model number would be more precise.
> [...] it only shows 750.5GB free space available on the router page.
750.5GB or 750.5MB? How is the drive partitioned? File system(s)?
You might need to connect it to a real computer to see how it's
configured. It's possible that 14TB is bigger than the (lame)
ReadySHARE software can handle. Or, you're seeing only one of multiple
partitions.
I can't (yet) see your picture. In-line images must be approved by
a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.
yorkee
attached screenshot as image. Thank you for helping me out.
