Philrowe1978
Mar 16, 2021Follower
Ac2200 range has dropped
Hello. My ac2200 extender was working fine but recently disconnected itself. It wouldn’t pair via wps but managed to pair in browser. But now rooms where I could see it’s extended networks (5G and 2g)...
Mar 17, 2021Guru - Experienced User
What actual extender do you have? AC2200 is a speed.
What router is it connected to?
What firmware did you install?
Are you using smart connect/one ssid?
You might also get different, more targeted help in the extenders section and not the routers section of the forums.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
