HeliumB
Jan 26, 2022Follower
AC2300 Nighthawk - Where to change NAT type to Open
I couldn't find the Model type in the list, so hopefully this isn't some bootleg model, but in following all of the directions online regarding the routerlogin.net process for changing NAT type, I ca...
Feb 01, 2022Guru - Experienced User
You can also set NAT Filter from Secure to OPEN under Advanced tab/WAN setup.
HeliumB wrote:
I couldn't find the Model type in the list, so hopefully this isn't some bootleg model, but in following all of the directions online regarding the routerlogin.net process for changing NAT type, I cannot replicate them. All of them mention a maintenance area I do not see on the attached devices screen, and all of them mention a protocol forwarding I don't see on the attached devices screen. I checked in the advanced menu as well, and cdo not see either of those options. Can someone assist?
