aesmith6's avatar
aesmith6
AC2300 Nighthawk R7000p
Must reboot router often.  Spectrum Fiber service.  Strong connection to modem, but router seems to intermittently slow down the speed.  I have read that the router may be overheating?  I reboot from the Nighthawk app and from plug/unplug.  Usually after a reboot the service will resume, but eventually degrades.  Any ideas?  Thanks.
1 Reply
    What is the manufacturer's name and model number of the optical network terminal (ONT) you are connecting the router to?
    Is there a chance it is a combination device that is also a router?
    Overheating is a possibility.  Do you live in a hot climate?  Is the router stacked on top of other electronic equipment?
