Enomwoyi's avatar
Enomwoyi
AC2300 nighthawk router flashing lights
My R7000P Nighthawk AC2300 router has started flashing lights in a weird sequence when plugged into the power. I've tried holding down the reset button for 30 seconds, I've tried different outlets. When attempting to update the tftp settings, the router isn't even detected when plugged into my PC. It seems bricked, is there anyone else with a similar problem and/or solution?
Thank you.
    • Enomwoyi's avatar
      Enomwoyi
      Thank you for the suggestion! I have ordered a 12v5a power supply to test out, which should arrive on Friday. I will update whether or not this solution works, then try the netgear unbrick github suggestion.
      • plemans's avatar
        Not sure if the power supply option will work. Was just something to try.
        Usually people have one sitting around that matches voltage/polarity that they can try.
