Mikecc419
Feb 18, 2021Aspirant
Ac2300 R7000P cant connect to reolink battery operated camera
Had a older N600 router that worker fine with camera have checked everything Reolink has suggested except for this. Cause 7. The Wi-Fi frequency is out of supported range Solution: Please set the ro...
Feb 18, 2021Guru - Experienced User
the R7000P only supports 20/40hz for the 2.4ghz channel.
What firmware is on the router?
What gateway/modem is it connected to?
what issue do you run into during setup?
What camera is it?
when you're setting it up, is your phone connected to 2.4ghz?
What 2.4ghz channel are you using on the router?
- Mikecc419Feb 18, 2021AspirantYes phone is on 2.4, have the 5g turned off on router and forgotten on phone, the firmware I do really know but it does have latest updates per the genine.the camera I using is a reolink argus eco. The problem I run into is when adding the camera after factory reset and deleting from app, when adding the camera I get to the connecting to router it tries for about a minute the says wifi connection failed
- plemansFeb 18, 2021Guru - Experienced User
Log into the router through the browser. The status page should have the firmware.
Plus you can check which channel you're using for 2.4ghz to broadcast on.
also, check the ssid/password. make sure there isn't any special characters/spaces in the ssid/password.
I've seen IoT devices with issues using them.
- Mikecc419Feb 18, 2021AspirantI have tried the reolink suggested channels 1, 6 and 11 and yes have checked passwords for characters, what firmware should I be looking for, the latest version or what.
Thanks for your input
- Mikecc419Feb 18, 2021AspirantThe gateway modem is what was supplied by spectrum same modem was in use on the older n600 router all that us new is the ac2300 nighthawk
