Mikecc419
Feb 18, 2021Aspirant
Ac2300 R7000P cant connect to reolink battery operated camera
Had a older N600 router that worker fine with camera have checked everything Reolink has suggested except for this. Cause 7. The Wi-Fi frequency is out of supported range Solution: Please set the ro...
Feb 18, 2021Guru - Experienced User
Log into the router through the browser. The status page should have the firmware.
Plus you can check which channel you're using for 2.4ghz to broadcast on.
also, check the ssid/password. make sure there isn't any special characters/spaces in the ssid/password.
I've seen IoT devices with issues using them.
Mikecc419
I have tried the reolink suggested channels 1, 6 and 11 and yes have checked passwords for characters, what firmware should I be looking for, the latest version or what.
Thanks for your input
