tngolfgame
Jul 11, 2024Aspirant
AC2300 Router Encryption
Having a Nighthawk AC2300 router I am having difficulty in determining just how strong the encryption offered by my device?
Jul 11, 2024Guru - Experienced User
What model # router do you have? AC2300 is a wifi speed.
Review the online spec sheet and user manual for supported security modes. Generally, WPA2 and AES is the most you'll see on R series routers.
- tngolfgameJul 11, 2024Aspirant
The model is R7000P
- FURRYe38Jul 11, 2024Guru - Experienced User
đ
