mgdbock
Jan 20, 2023Aspirant
ac2300 speed is slower than it should be
Hello all, I recently upgraded my internet service from 200 Mbps to 600 Mbps and my modem to an Arris surfboard 3.1 docsis. I also installed new cat6 cables. However, my Nighthawk ac2300 router is...
Jan 20, 2023Guru - Experienced User
What model router do you have? AC2300 is a wifi speed.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- mgdbockJan 20, 2023Aspirant
Thanks for the reply.
Modem is Arris sb8200. Router is r7000p. I have new cat6 cables. Firmware is V1.3.2.134_10.1.66
The last thing I did was a factory reset of the router and resetting the SSIDs.
I changed the DHCP IP address range (under LAN setup) and then power-cycled. No change.
What did you mean by #? I assumed it was to use the number that was already there.
- FURRYe38Jan 20, 2023Guru - Experienced User
Yes.
What are speed seen over a ethernet connected PC using Ooklas installable speed test app?
Unfortunately, my laptops don't have an ethernet port. My desktop is in a far room. I guess I'll either get a long cable, usb-ethernet dongle, or set my old rig up for a test this weekend.
Again, thanks again for the quick replies.
