mgdbock
Jan 20, 2023Aspirant
ac2300 speed is slower than it should be
Hello all, I recently upgraded my internet service from 200 Mbps to 600 Mbps and my modem to an Arris surfboard 3.1 docsis. I also installed new cat6 cables. However, my Nighthawk ac2300 router is...
mgdbock
Thanks for the reply.
Modem is Arris sb8200. Router is r7000p. I have new cat6 cables. Firmware is V1.3.2.134_10.1.66
The last thing I did was a factory reset of the router and resetting the SSIDs.
I changed the DHCP IP address range (under LAN setup) and then power-cycled. No change.
What did you mean by #? I assumed it was to use the number that was already there.
Jan 20, 2023Guru - Experienced User
Yes.
What are speed seen over a ethernet connected PC using Ooklas installable speed test app?
- mgdbockJan 20, 2023Aspirant
Unfortunately, my laptops don't have an ethernet port. My desktop is in a far room. I guess I'll either get a long cable, usb-ethernet dongle, or set my old rig up for a test this weekend.
Again, thanks again for the quick replies.
- FURRYe38Jan 20, 2023Guru - Experienced User
Usb to ethernet adatpers are pretty cheap these days.
