1Everett1
Dec 26, 2021Aspirant
AC2300 Wi Fi Router Model R7000P
AC2300 Wi Fi Router Model R7000P can I add an extender
Dec 27, 2021Guru - Experienced User
Yes you can add extenders to the R7000P.
I'd recommend only adding 1. If you're needing more than 1, I'd recommend moving to an actual mesh system.
- 1Everett1Dec 27, 2021AspirantThank you. Do you have a recommendation for the type of extender. Maybe going less then 75 feet?
- plemansDec 27, 2021Guru - Experienced User
I'm a fan of the triband line of extenders. They have higher throughput and lower latency because of their dedicated backhaul.
But if you're just needing a little more coverage, then a decent dual band extender would work as well.
