1Everett1
Dec 26, 2021Aspirant
AC2300 Wi Fi Router Model R7000P
AC2300 Wi Fi Router Model R7000P can I add an extender
Dec 27, 2021Guru - Experienced User
Yes you can add extenders to the R7000P.
I'd recommend only adding 1. If you're needing more than 1, I'd recommend moving to an actual mesh system.
1Everett1
Dec 27, 2021Aspirant
Thank you. Do you have a recommendation for the type of extender. Maybe going less then 75 feet?
- plemansDec 27, 2021Guru - Experienced User
I'm a fan of the triband line of extenders. They have higher throughput and lower latency because of their dedicated backhaul.
But if you're just needing a little more coverage, then a decent dual band extender would work as well.
