PTFInn
Oct 21, 2024Follower
AC2300 WiFi Router (R7000P)
Hello, I have a Netgear Nighthawk AX2.300 smart Wi-Fi router, Model R7000P. I am trying to change the device name on an Xbox One, of which we have three on the Wi-Fi. I see where I can edit the devic...
Oct 21, 2024Guru - Experienced User
What FW is loaded on the router?
What browser are you using?
Try a factory reset and setup from scratch to see if then you can set a new name for each device on the router.
I presume your trying to setup an IP address reservation?
