earlyshooter
Mar 19, 2021Aspirant
AC2400, Horrible packet loss and ping
I've had issues like this in the past and the way I fixed it was by updating the firmware. Now that these problems have returned I've gone ahead and hard reset the router and the firmware is up to da...
earlyshooter
Update: I think the problem wasn't the router but rather the modem. doing a simple reset got rid of most of the ping issues. If need be I'll do a hard reset on the modem and that should make things better.
- plemansMar 20, 2021Guru - Experienced User
What modem do you have?
Do you have a screen snip of the modems cable connections page and the logs?
