kurak38
Apr 30, 2023Aspirant
AC2400 how to disable internet on some devices
Hi,
I am trying to secure my ip camera in the house and I want to block them from accessing internet, so I can only connected to them when I VPN to home network. How do I achieve that with AC2400? ...
kurak38
I have NETGEAR Nighthawk AC2400
| Firmware Version | V1.2.0.92_1.0.1 |
About the setup that is what I did, as you described, but it does not add devices when I click Add:
it shows dialog
and then nothing pops on the list od blocked services
microchip8
Apr 30, 2023Master
Must be a bug in the firmware. I can confirm it works here, but I use a different router & firmware
You can try using the Nighthawk app and pausing the Internet there.
- kurak38Apr 30, 2023Aspirant
yeah I tried Nighthawk app and it has toggle to turn off internet for given devices but it does map to main Access Control panel and blocks devices from local communication as well đ
