kurak38
Apr 30, 2023Aspirant
AC2400 how to disable internet on some devices
Hi,
I am trying to secure my ip camera in the house and I want to block them from accessing internet, so I can only connected to them when I VPN to home network. How do I achieve that with AC2400? ...
microchip8
Apr 30, 2023Master
AC2400 is not a router model but a speed. What is your router model?
Which firmware do you run? Not "the latest" but a version.
As for blocking Internet;
- Go to Advanced -> Security -> Block Services
- Set Service Type to User Defined, set protocol to TCP/UDP
- Set Start Port to 1 and End Port to 65535
- Give a name to your device in "Serive Type/User Defined"
- Enter its IP address. It's best to DHCP reserve an IP address to your device so it always gets the same one.
michaelkenward
May 01, 2023Guru - Experienced User
The one freaky Netgear device where the twerps in marketing picked the speed label for the model number.
Nighthawk AC2400 | AC2400 Smart WiFi Router | NETGEAR Support
Fortunately it was a one off.
