bbombassei
Nov 18, 2023Aspirant
AC2400 No Wifi After Restart
Whenever I have to reboot my router, all of my devices that connect via wifi have trouble reconnecting. Sometimes the wifi will come back, but most of the time it does not. I usually have to restore ...
Nov 18, 2023Guru - Experienced User
What router model do you have? R####?
What FW is loaded?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try a factory reset and setup from scratch then save off a backup configuration to file:
bbombassei
Firmware is V1.2.0.92_1.0.1. Router model is Nighthawk AC2400. I don't see an R# anywhere on the router. I had just changed the channel to 7 today for 2.4 and 153 for 5g but that didn't help. I have wifi neighbors nearby but nothing crazy close, I'd say about 300 ft. Using WPA2-PSK [AES] if that matters. Going to try these channels and see if it works, if not I'm going to do a factory reset again and make a backup.
