bbombassei
Nov 18, 2023Aspirant
AC2400 No Wifi After Restart
Whenever I have to reboot my router, all of my devices that connect via wifi have trouble reconnecting. Sometimes the wifi will come back, but most of the time it does not. I usually have to restore ...
bbombassei
Firmware is V1.2.0.92_1.0.1. Router model is Nighthawk AC2400. I don't see an R# anywhere on the router. I had just changed the channel to 7 today for 2.4 and 153 for 5g but that didn't help. I have wifi neighbors nearby but nothing crazy close, I'd say about 300 ft. Using WPA2-PSK [AES] if that matters. Going to try these channels and see if it works, if not I'm going to do a factory reset again and make a backup.
bbombassei
Yeah none of that worked. I had to do a factory reset and put my SSID/PW back in and now I'm good again. I really don't know what's causing it to do this, very frustrating. Never had issues in the past, don't think anything has changed so I'm leaning toward something wrong with the router? Then I think it can't be the router since a factory reset fixes it? I'm stumped.
