tdcunningham
Nov 24, 2018Aspirant
AC2400 only lets device connect to Guest account
Netgear "customer support" is a never ending circle of nothing, so hopefully the community can help.
Just bought an AC2400 wifi router, it's running V1.2.0.32_1.0.1 firmware. I'm using 'Access ...
- Dec 01, 2018
Just bought this router also had the same issue with only connecting to Guest network for wireless , I just simple unchecked the box for smart connect , for wirelessl , after that not a problem , router works great
DarrenM
Nov 27, 2018Sr. NETGEAR Moderator
Have you tried to remove the wireless networks saved in the laptops wireless settings then try to connect to the network again?
DarrenM
- Jojoe64Dec 01, 2018Initiate
Also I forgot to mention , use the Netgear genie webpage on computer to change the setting , if you cannot connect to computer using wireless , plug a landline into your computer that is connected to your router , type into your browser 192.168.1.1 to access Genie webpage , login is '' admin '' password is the password that is on your router , or the one you created
- tdcunninghamDec 02, 2018Aspirant
Yup, that's what it was. So much for it being 'Smart'.
Thanks for the reply!!
Thanks for the suggestion, I tried that after removing the wifi adapter from device manager, but it still didn't work.
Turns out the fix is unchecking the 'Smart Connect' feature that (supposedly) lets the router select the WiFi band.
