tdcunningham's avatar
tdcunningham
AC2400 only lets device connect to Guest account
Netgear "customer support" is a never ending circle of nothing, so hopefully the community can help.   Just bought an AC2400 wifi router, it's running V1.2.0.32_1.0.1 firmware. I'm using 'Access ...
  • Jojoe64's avatar
    Jojoe64
    Dec 01, 2018
    Just bought this router also  had the same issue with only connecting to Guest network for wireless  , I just simple unchecked the box for  smart connect , for wirelessl , after that not a problem , router works great
