tdcunningham
Nov 24, 2018Aspirant
AC2400 only lets device connect to Guest account
Netgear "customer support" is a never ending circle of nothing, so hopefully the community can help.
Just bought an AC2400 wifi router, it's running V1.2.0.32_1.0.1 firmware. I'm using 'Access ...
- Dec 01, 2018
Just bought this router also had the same issue with only connecting to Guest network for wireless , I just simple unchecked the box for smart connect , for wirelessl , after that not a problem , router works great
Jojoe64
Dec 01, 2018Initiate
Jojoe64
Also I forgot to mention , use the Netgear genie webpage on computer to change the setting , if you cannot connect to computer using wireless , plug a landline into your computer that is connected to your router , type into your browser 192.168.1.1 to access Genie webpage , login is '' admin '' password is the password that is on your router , or the one you created
