Retired_Member's avatar
Retired_Member
Jan 17, 2022
AC2400 router randomly dropping Internet connection
Hi.  I have an AC2400 router connected to a Rogers Ignite gateway that's acting only as a modem.  For the past couple of years, everything has worked flawlessly.  Connected devices include a NAS, a c...
  • Retired_Member's avatar
    Retired_Member
    Jan 28, 2022
    Follow-up and final comment: Turns out it wasn't the router or even the gateway/modem.  After several calls to Rogers and visits by 2 technicians, the problem was diagnosed as (a combination of) a badly corroded connection in the nearby network node and an unnecessary splitter in the cable box attached to the side of my house.  The connection was replaced, the splitter was removed...and everything seems to be working fine.  I'll be re-installing the router shortly.  Thanks again to plemans for the assistance.  :)
