joesmo
Sep 23, 2021Aspirant
AC2400 wifi not working at all after V1.2.0.88_1.0.1 firmware update
I don't know what is going on. Before I did the firmware update my 2.4GH internet was working. Not my 5G. Now, I have done the update and neither work. the lights are not working on the router and pl...
Sep 23, 2021Guru - Experienced User
yes, if the light is on but not blinking, it usually means nothing is connected/transmitting on it.
Do you have a 5ghz device you can connect to it?
joesmo
Yes. I've been monitoring it with my iphone to see if a signal ever pops up in my iphone wifi settings. But nothing yet. So we know the radio signal for 5G is working and we know wired and 2.4 wifi is working too. So something specific to 5G.
- plemansSep 23, 2021Guru - Experienced User
Any other devices you can try?
Did you log into the router to see if the ssid broadcast was disabled?
Have you tried a wireless channel scanner like inssider?
