bob1951's avatar
bob1951
Initiate
Feb 08, 2023
AC2600 Model R7450 Unable to connect to internet. I get a secure connection but no inernet.
Model Number R7450
Firmware Version v1.2.0.92
App Version 2.23.0.2673
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
  • michaelkenward's avatar
    michaelkenward
    Any chance of some details about your problem?
    Something about "secure connection but no internet"?
    What tells you that?
    If this is a connection through a Windows PC, then maybe you need to tell the PC that you are on a private network.
    Windows 11:
    Properties
    That's just a guess based on incomplete understanding of what your problem might be.
