User007M
Jun 02, 2023Aspirant
AC2600 not connecting
Recently moved to a new house with same ISP. Computer connects to internet when directly connected to modem (CM1200), but no longer connects when plugged into modem via router. Other wireless devices ...
Jun 02, 2023Guru - Experienced User
What model router do you have? AC2600 is a wifi speed.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure your only connecting the router to the CM modems WAN port 1 and remove all other devices from the CM modem. These are not LAN ports.
User007M
Model R7450.
I will attempt the steps you mentioned and will update the status.
- FURRYe38Jun 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
