User007M
Jun 02, 2023Aspirant
AC2600 not connecting
Recently moved to a new house with same ISP. Computer connects to internet when directly connected to modem (CM1200), but no longer connects when plugged into modem via router. Other wireless devices ...
User007M
Model R7450.
I will attempt the steps you mentioned and will update the status.
Jun 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
