User007M
Jun 02, 2023Aspirant
AC2600 not connecting
Recently moved to a new house with same ISP. Computer connects to internet when directly connected to modem (CM1200), but no longer connects when plugged into modem via router. Other wireless devices ...
michaelkenward
Jun 02, 2023Guru - Experienced User
It may be the same ISP. but you have changed quote a few things on our network.
Did you set up whatever this AC2600 is from scratch.
There may be some subtle changes in the local network configuration.
If the router is delivering as it should, there's a couple of easy options
- Go onto the router's browser graphical user interface (GUI) and take it through the Internet setup wizard
- Reset the router and set it up from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Find more in the manuals for your router.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
That page will also have any software, firmware and drivers for your device, if they exist.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
