HemD
Jun 03, 2022Aspirant
AC3000 Model R7900 Factory Reset
I have tried to factory reset the AC3000 Router several times and I still cannot access the router by using the default password. Is there anything that I need to do to access the router using the fa...
Jun 03, 2022Guru - Experienced User
When you're pushing and holding reset, are you holding for up to 30 seconds while its powered on?
