ssriram1978
Apr 25, 2017Aspirant
AC3200, R8000 does not support "dev tun"
I am trying to use openVPN client in my iOS device to connect to my AC3200 router. AC3200 does not support "dev tun" option in the ovpn setting. I am unable to login to my VPN from iOS device. How...
- May 23, 2017
Apr 26, 2017Guru - Experienced User
Thank you Elaine.
ssriram1978
Apr 26, 2017Aspirant
Thank You.
Here is the client debug log and it clearly points out the failure reason.
2017-04-26 10:52:46 SSL Handshake: TLSv1.0/TLS-DHE-RSA-WITH-3DES-EDE-CBC-SHA
2017-04-26 10:52:46 Session is ACTIVE
2017-04-26 10:52:46 EVENT: GET_CONFIG
2017-04-26 10:52:46 Sending PUSH_REQUEST to server...
2017-04-26 10:52:46 NET Internet:ReachableViaWWAN/WR t------
2017-04-26 10:52:46 OPTIONS:
0 [route] [192.168.0.1] [255.255.255.0]
1 [route-delay] [5]
2 [redirect-gateway] [def1]
3 [route-gateway] [dhcp]
4 [ping] [10]
5 [ping-restart] [120]
2017-04-26 10:52:46 PROTOCOL OPTIONS:
cipher: AES-128-CBC
digest: SHA1
compress: LZO
peer ID: -1
2017-04-26 10:52:46 EVENT: ASSIGN_IP
2017-04-26 10:52:46 TUN Error: tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified
2017-04-26 10:52:46 EVENT: TUN_SETUP_FAILED tun_prop_error: one of ifconfig or ifconfig-ipv6 must be specified [ERR]
2017-04-26 10:52:46 EVENT: DISCONNECTED
2017-04-26 10:52:46 Client exception in transport_recv: tun_exception: not connected
2017-04-26 10:52:46 Raw stats on disconnect:
BYTES_IN : 3498
BYTES_OUT : 2619
PACKETS_IN : 35
PACKETS_OUT : 35
TUN_SETUP_FAILED : 1
2017-04-26 10:52:46 Performance stats on disconnect:
CPU usage (microseconds): 79480
Network bytes per CPU second: 76962
Tunnel bytes per CPU second: 0
2017-04-26 10:52:46 EVENT: DISCONNECT_PENDING
2017-04-26 10:52:46 ----- OpenVPN Stop -----
- ElaineMMay 23, 2017NETGEAR Employee Retired
- ssriram1978May 23, 2017Aspirant
Thank you. The latest firmware has the ios ovpn details and it works fine.
Thank you for the confirmation.
Have a great day!
