Olduser69
Nov 08, 2017Aspirant
AC3200 rebooting issues
I am having an issue with my Router rebooting all the time. This happened since downloading and instaling the newest firmware for security reasons. I am having the same issues as this topic ( https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-rebooting/td-p/494441/page/2 )
I thought by spending $300 for a top of the line router I wouldnt have connection issues but it seems this model is super buggy since the update. I bought the unit in July and never had rebooting issues or IP changes. Now when it reboots it changes the ip's of a few connections. I have since reserved the ip's so they dont change (for remote vpn login reasons). I get regular loss of wifi signal on the 5ghz signals. I only attach 1-2 streaming media devices to those ports (amazon fire stick, apple tv ect...) and they seem to work ok for a while but drop after about 45min of use.
Any ideas on this. It seems that this model has been buggy for years since it was released. I only have 2 hard line connections and around 5-8 wifi connected devices at a time. Again as I said I havent had an issue until the firmware was updated. It seems like it corrupted the router.
Hi Olduser69,
Try to reset the router to factory default.
- JamesGLNETGEAR Employee Retired
Hi Olduser69,
Hi Olduser69,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Olduser69AspirantI reset the router and it did not change. Router kept rebooting. I did find however that one PC on my lan network was compromised and apparently someone had got in through an open port/vpn setup and was manually rebooting my router. Unsure if it was ISP or an attacker. I have since rebooted router again and closed all ports and disabled VPN with OpenVPN I had set up. I switched OS and have not had a single reboot issue since. I will monitor this issue and report back if I continue having issues. It’s been over a week now with no reboots.
